Hi everyone
So the problem im facing is that my Forza Horizon 4 game is underperforming. I am getting an average of 52 FPS on 1080P on ultra.
I have already tried the following
Updated BIOS
Updated chipset
updated windows
updated gpu drivers to latest
Reinstalled windows
repeated driver updates
tried overclocking ram and cpu except gpu( For some odd reason the games crashed when running msi afterburner) but anywho, game is suppose to perform better like the rest of the videos on youtube.
no luck as of yet
GPU usage fluctuates between 80 to 97
A friend of mine is getting 60 to 80 on high with a gtx 1060 3GB!Untitled1.thumb.png.2d811fa2af3f1a6d9985fcd25dcc9ade.png...while im at 38 in races on ultra....
Specs
Cooler master Masterbox MB511RGB
Cooler master masterliquid ML240L cpu cooler
Intel core I5 8600K stock clocks
Zotac RTX 2070 Mini
cooler master MWE 550w psu
asus Z370-I motherboard
g.skill tridentz RGB 3000mhz memory
Any help would be appreciated.
https://linustechtips.com/topic/1096182-rtx-2070-low-fps/
Do you use a PCI-E riser cable?
Do you use any kind of power adapter on your GPU?
Have you checked if your GPU sits correctly in its 16x pci-e slot and is using its 16x Pci-E lanes properly?
Have you checked temperatures and/or coreclocks of your GPU and CPU while gaming?
Do you get more fps if you lower your settings or resolution?
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
https://linustechtips.com/topic/1096182-rtx-2070-low-fps/#findComment-12825384
2 minutes ago, Ruan1158 said:
No riser cable, no adapters. Will quickly ensure that its properly seated, cannot check temps as FPS Monitor crashed the game for some reason, can you recommend another program?
hwinfo / hwmonitor / GPU-Z just check for max temps, can run in the background you dont need to use onscreendisplay.
If using GPU-Z you can also see if your card is properly seated when its using 16x PCI-E lanes while gaming.
https://linustechtips.com/topic/1096182-rtx-2070-low-fps/#findComment-12825404
gpu perfectly seated no problems at all, will get the temps soon
Ok, could also be the cards low powerlimit, but if temps are fine and clock is up you should consider contacting zotacs customer support, for further assistance.
https://linustechtips.com/topic/1096182-rtx-2070-low-fps/#findComment-12825430
