this is my first pc build and was hoping I could have input from others as to what/if I should change any of the parts on my build. I’m mostly going to be gaming, but I also would like as much “future proofing” and have room for more creative projects. (Streaming/video editing/photoshop etc) I have a budget of around $2100 for the PC itself. & $400 for a 1440p 144+ refresh monitor
cpu: Ryzen 3600x
Cpu cooler: Kraken x62
motherboard: X570 Taichi
memory: Trident z Royal 16gb 3600MHz 16 cas
Graphics card: 5700 XT red devil/ or a 2070
storage: Team group 1Tb pcie 3.0 x4
Storage2: 3Tb seagate barracuda 7200rpm
power supply: Corsair txm 850w 80+ gold
Case: Lian-li PC-O11 dynamic
Case fans: 6x Corsair HD-120 RGB
My questions: should I go for 32GB ram at 3200 MHz (for same price) even though 3600 is the “sweet spot” currently for my cpu? (More ram at the cost of a few FPS) also Couldn’t I overclock the 3200 to 3600?
Cpu cooling; should I go for a 360 AiO instead of a 280 for a more aesthetic look?
https://linustechtips.com/topic/1095570-need-input-for-first-time-build/
you don't need ram this expensive but it's very very pretty.
no guarantee
Primary PC:
PSU tier list
How many watts do I need?
I'll recommend this instead...
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($195.99 @ SuperBiiz)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($66.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Storage: Western Digital RE 2 TB 3.5" 7200RPM Internal Hard Drive  ($39.73 @ Amazon)
Video Card: EVGA GeForce RTX 2080 Ti 11 GB Black Video Card  ($1052.99 @ SuperBiiz)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Amazon)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($75.99 @ SuperBiiz)
Monitor: Acer XZ271U bmijpphzx 27.0" 2560x1440 144 Hz Monitor  ($269.99 @ Walmart)
Total: $2299.56
Generated by PCPartPicker 2019-08-19 00:48 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
4 minutes ago, Flacko said:
it is very pretty lol. I only considered spending the premium on it because of the 3600 MHz with a cas latency of 16.
You might find the Trident Z Neo priced more agreeably, still pretty as well
Primary PC:
PSU tier list
I found the royals for $190 while the neos are all sold out at the same specs as the royals. How much of a difference would 17 cas be to 16? I could save like $60 by switching to that slower latency
You could tune the timings, cas 16 down from 17 is certainly feasible
Primary PC:
PSU tier list
I'll recommend a 3200mhz cl16 kit.
There's no point in spending extra $120 on memory.
Total: $2299.56
SSD TIER LIST
CPU - Ryzen 7 3700X
