So I build this pc in my signature in March of this year, everything was working fine up until about a month ago. I started experiencing random BSOD for PAGE FAULT IN NONPAGED AREA. I figured my OC wasn't holding so i went back to stock on everything. This didn't seem to take care of the issue and still was getting random Bluescreens, I reinstalled windows and all was fine for a while up until today. I was just doing some web browsing and screen went black and the system restarted.
It now only gets up to the dots for loading windows and BSOD with SYSTEM THREAD EXCEPTION NOT HANDLED. THEN IT RESTARTS OVER AND OVER.
ON ABOUT THE THIRD TIME AROUND IT WILL GO TO PREPAIRING AUTOMATIC REPAIR SOMETIMES IT WILL MAKE IT TO THE MENU IF IT DOESN'T IT BSOD WITH EITHER THE SYSTEM THREAD EXCEPTION OR IRQL NOT LESS OR EQUAL
IF IT DOES MAKE IT TO THE MENU AND I SELECT REPAIR STARTUP OR ANYTHING ELSE IT EITHER FREEZES OR BSOD WITH IRQL NOT LESS OR EQUAL.
I HAVE TRIED TO BOOT TO WINDOWS USB INSTALLER AND WHEN IT LOADS IT BLUESCREENS IN THE INSTALLER NEVER MAKING IT PAST SELECTING A DISK TO INSTALL WINDOWS ON. BSOD IS DRIVER OVERRAN STACK BUFFER OR IRQL NOT LESS OR EQUAL.
I HAVE REFLASHED THE BIOS, TAKEN ONE STICK OF RAM OUT AND MOVED THEM AROUND TRYING BOTH STICKS, ALL DRIVES DISCONNECTED FROM THE SYSTEM EXCEPT USB MEDIA AND THE NVME INTENDED TO HAVE THE WINDOWS INSALL ON IT.
I HAVE REMOUNTED THE CPU.
OBVIOUSLY TIRED REINSTALLING AND REPAIRING WINDOWS. ALWAYS RESTARTS OR BLUESCREENS.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1095347-hardware-issue-narrowing-it-down/
