Hi there,
I've noticed that the 9750h keeps pulling above 1 volts and pretty much fluctuates up and down.
Is there a way to stabilize the Core voltage to 1 where it doesn't jump up and down, which I think will greatly improved the laptops thermals and also stabilize any applied undervolting?
I mean, my 6900k is also fixed to a steady voltage of 1.25 volts and simply decreases the voltage and clocks down if it's not used but doesn't fluctuate up and down at it's peak voltage.
Can I do this in throttlestop?
https://linustechtips.com/topic/1095226-razer-blade-static-cpu-vcore-possible/
Why?
It will only increase powerdraw, and using static voltage would mean a static clockspeed .
Voltage fluctuation does what it does to allow it to boost freely and lower powerdraw during non-use scenarios. Just do a couple of millivolt undervolt and see how it works out.
And if you are worried about temps, then dont be. Laptops are inherently hot.
47 minutes ago, GoldenLag said:
Why?
Well my desktop CPU clocks down too when there is no load but stays steadily at 1.25 volts when it's doing 4 GHz, isn't that possible with a laptop CPU?
Unless its an overclockable sku, then no. The best you can do is most likely undervolting.
Still, there is no benefit to locking voltage on a mobile device.
