Wired router recommendation
IgorM
I'm looking for a wired gigabit router for home use for connecting one AP and two computers that isn't very expensive. Any suggestions?
2 hours ago, Electronics Wizardy said:
how much bandwidth do you need? Do you need advanced features like ips or vpn?
Id probably just get something like a edge router x, this guy https://www.amazon.com/Ubiquiti-EdgeRouter-Advanced-Gigabit-Ethernet/dp/B00YFJT29C/ref=sr_1_3?keywords=edgerouter&qid=1566069690&s=electronics&sr=1-3
No advanced features, just Port forwarding at most. Maybe 100 Mbps with possibility to upgrade to 300 Mbps.
Good suggestion but Ubiquiti is quite expensive where I live, if I'm very very lucky I can find a used one.
Look at mikrotik as well, they have good routers in this feature set.
You can also just take an old computer and put untangle or pfsense on it aswell.
