Which smart devices come with the Corsair 680X RGB?
Solved by Origami Cactus,
If it includes lighting node pro, it also includes the lighting rgb hub, where you can plug up to 6 rgb fans.
To control the fan speeds, you can either plug the fans directly into the motherboard, or you can use Y-splitters, or you can use a pwm hub, or a pwm controller.
Featured Topics
Tyraenel ·
XxWOODSIExX ·
Posted in Troubleshooting2 -
Pove ·
Posted in New Builds and Planning7 -
4
tommmie20000 ·
Posted in Audio5 -
INotPablo ·
Posted in Cases and Mods2 -
Pove ·
Posted in Power Supplies6 -
Knugen1015 ·
Posted in Windows3
