my cpu is always at 100% when i play rainbow six siege whether i have discord and or spotify open at the same time or not. my gpu is an MSI armoured rx 580 and my cpu is an i5-6400 4 core. it's a bad cpu i've heard and im thinking of upgrading but is it normal for me to be at 100%? also, if i do upgrade any suggestions on what i should upgrade to?
https://linustechtips.com/topic/1094697-i-need-help-with-my-cpu/
That's normal with r6s as it's a heavily cpu bound game. The best you can upgrade to on your platform is to an i7 7700
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Ha, I can tell you from experience that this isn’t surprising. I wouldn’t nessescarily be worried about it
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
1 minute ago, Skiiwee29 said:
That's normal with r6s as it's a heavily cpu bound game. The best you can upgrade to on your platform is toban i7 7700
Well, not to mention that the i5-6400 is also kind of cold garbage
It's not cold garbage, just depends on the game and how it utilizes the resources.r6s uses cpu way more than anything.
Community Standards
"Beast Mode"
Experience disagrees, but I get what you are saying
It kind of is, the 6400 is extremely low clocked, to the point where it can't keep up with the previous gen i5s and barely matches the 4460. It was universally laughed at in 2015 and is still not good today.
Just now, Fushiatic said:
would i need to upgrade my motherboard?
With an i7 7700 - no. Only a BIOS update. But unless you can find an i7 under 100$, I'd look at a more modern AM4 board and CPU since paying over 100$ for a 4/8 i7 is ludicrous
