Hi fellas it's been a while since I've built a pc. Purchased a x570 aorus pro mobo. Decided to reuse my evga G2 750w PS. There is an additional 4 pin next to the 8pin EPS. I don't believe I have a connector for this. Is it necessary or is it a matter of purchasing a new ps?
https://linustechtips.com/topic/1094426-atx_12v1/
You don't have to use extra 4 pin connector. 8 pin will do the job.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1094426-atx_12v1/#findComment-12811043
1 minute ago, Quagral said:
What's the 4 pin for??
For when you have Ryzen 9 3900x overclocked to 5Ghz under LN2.
https://linustechtips.com/topic/1094426-atx_12v1/#findComment-12811063
