Basically i was building a pc for my friend and he accidentally got and sfx psu rather that a full atx one, i was just wondering if it would make any difference.
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
https://linustechtips.com/topic/1094388-will-it-make-a-difference/
SFX power supplies are more expensive than normal power supplies so sending it back and buying a cheaper unit would make sense, but which unit did you get?
Primary PC:
PSU tier list
How many watts do I need?
Actually the reason he accidentally bought it was that it was cheaper at the time ...
Which unit
Primary PC:
PSU tier list
Just now, fasauceome said:
Which unit
EVGA 550w gold don't know it exactly but its in blue writing if that helps
there should be no issues with it.  SFX PSUs usually have a few less cables included  so if your putting in a ton of SSD's or GPUS then it would be an issue but at 550W it seems like this is a fairly standard system
ok thank you i didn't think there would be but there is no harm in double checking
It's probably their SFX G series unit then, which is fine. It works the exact same way as a normal PSU. Pretty sure that model comes with an adapter bracket too, so it fits a case for normal PSUs.
Primary PC:
PSU tier list
Ok thanks
