I want to get a Razer blade 15. Because it looks nice. The build quality seems nice. I don't play games often, but I would like to have a good performance machine. My budget is $1000 to $2000. Do you recommend getting base model with gtx 1060 or rtx 2060. Also, do you recommend renewed products?I really like razer
https://linustechtips.com/topic/1093984-razer-blade-15/
There are much, much better laptops than that for cheaper. I'm not very knowledgable about gaming laptops, but if you don't need a ton of GPU power a Thinkpad is a great investment.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807252
I like Thinkpad, but I love the design of razer blade.
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807267
Razer isnt good tbh, the thermal solution was bad. the 2019 is better but decent and not the best. and the build well.............
if you want powerful machine i always go with the Y540 Y740 or Asus ROG
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807269
Buying a bad product because you like the aesthetic is a terrible idea. Hell, buying a Razer laptop is a terrible idea, regardless of if you like the aesthetic or not.
Get a good machine, not a shit one that looks good.
SPECS:
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807276
In this video he said it's a great product
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807287
Great because of design. display. but the cooling decent. we arent prepared for thin gaming yet. and there plenty of other you should check it out
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807294
Since I don't play games a lot, I don't think I need the best cooling. I would rather get thin laptop that performes decent
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807318
Do you recommend rtx version of razer blade or gtx version?
GTX if you want to limit your budget. i meant i personally don't use RTX because the purpose of RTX its to utilize the ray-tracing technology. and its really take a huge toll on everything.
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807325
Is gtx 1060 good for most games? Such as fortnite apex, pubg, battlefield?
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807330
fornite is good.
the rest is decent. especially battlefield that hungry power.
but your 1060 is 1060 MAX-Q which is better and cooler compare to standard MObile 1060.
- Fortnite Ultra setting around 70Fps
- Apex Legend 60fps but might drop
-PUB G ultra setting 50-60 ish
-BF5 probably high 60fps
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807371
fornite is good.
Thx
https://linustechtips.com/topic/1093984-razer-blade-15/#findComment-12807377
