LMG guys,
I love your content.  Keep up the good work.
I have an idea for some videos I'd like you to consider.
I have the Samsung UN78JU7500 - a 78 Inch curved TV that has excellent input lag (<20ms) for a TV its size.  No other large TV (75" or larger) came close in 2015.  I have been contemplating a replacement.  The problem I have is finding input lag data on these TVs.
I used to use displaylag.com and search their database.  The problem is they rarely check TVs in this size category.  The most recent TV they tested in this size category is a 75" from 2018.  Zero tests from 2019.  Only one from 2018. One from 2016.  Four from 2016.  Two from 2015.  The 75" tested this year, the LG 75UK6570PUB, looks amazing, but I would rather get the 86" version, and have no way to tell if its display lag is as good as the 75".
I know NVidia is pushing their BFGDs, but I have not seen anything near this size, and quite frankly do not want to pay for things like GSync on my TV, even if I am gaming on it.  That 75" from LG that I mentioned is $2500 right now.  A 65" BFGD (HP Omen) is $5000... I can't see paying twice as much for a TV that has 25% less real estate even if it has GSync.
I would LOVE to see you guys start a series of videos devoted to input lag on large televisions.  I am wondering if any other viewers would also be interested.
https://linustechtips.com/topic/1093424-input-lag/
rtings.com has a good selection of TV reviews that includes input lag tests.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1093424-input-lag/#findComment-12802811
