Back at it again with another completed project. This time, the stakes are higher than a Canadian flag on July 1st.
Project Maple is my entry into the Cooler Master Case mod world series novice modding division.
This was proudly sponsored by Swiftech USA who provided me with pretty much every single piece they sell.
Build List:
Mobo - Asus Maximus X Code - Painted
CPU - i5 9600k @ 4.8ghz
GPU - MSI 1080ti Aero OC
Ram - TeamGroup T-Force Nighthawk 4x8gb 3200mhz
SSD - TeamGroup T-Force 240gb
PSU - Seasonic focus+ Gold 850w
Case - Cooler Master MB530p with plenty of cosmetic mods.
Watercooling:
CPU - Swiftech Apogee SKF Prestige w/Iris ARGB
GPU - Swiftech Komodo 1080ti w/CMWS19 painted backplate.
Pump/Res - (Cut down to 170mm) Swiftech Maelstrom 200mm(170mm) d5 w/Iris ARGB
Radiators - 3x Swiftech Hydrae GT(120/240/360) Painted Tornado red
Compression Fittings - Nanoxia CF 16mm hardline painted
Angled and extension Fittings - Swiftech Dual 45 rotary &15mm
Drain - Dazmode Darkside Pushvalve
Fluid - SwifTech "Mayhem" Dyes in distilled, and 1 drop of Dead Water
Misc:
Fans - Swiftech Helix 120mm w/Iris ARGB
Controllers - Swiftech Iris ARGB Eco Controllers
Cables - Tpbmods created, using Telios Sleeving from Mainframe Customs
Cable Combs - Nanoxia CF with splatter paint job
Paint - BombingScience.Com Ironlak/Moltow/FlameBlue
https://linustechtips.com/topic/1091932-cmws19-project-maple/
Nice!! The colors are epic!
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1091932-cmws19-project-maple/#findComment-12791946
Awesome looking build! I love the color scheme and the splatter details, epic work. :) You've certainly done Canada proud with this gorgeous build. :D
How long did this whole build take you? It looks like you've put so much effort and detail into it and it's well paid off for you. :)
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1091932-cmws19-project-maple/#findComment-12793932
Thank you very much for the kind and loving words @seoz
Start to finish was basically 8 hours a day every tues/wed(my weeekend) from July 2nd till Aug 7th.
Im really hoping it pays off in the CMWS19, Builds.gg has been loving it
https://linustechtips.com/topic/1091932-cmws19-project-maple/#findComment-12795130
I applaud your dedication put into your build, it is a lovely end result and you should be very proud of it. :) Your build is going to be a hit, I'm sure!
https://linustechtips.com/topic/1091932-cmws19-project-maple/#findComment-12795561
