Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783541
7 minutes ago, Baxman293 said:
Hi all,
I cant find the answer im looking for anywhere, what sort of ram do i need to run with these parts
ryzen 5 3600
ASRock b450m Steel legend
Thanks for any help
DDR4 3200 ~ 3600, preferably one with low latency.
3 minutes ago, Baxman293 said:
will they work with a Gigabyte b450m s2h?
also would this ram work? https://www.pbtech.co.nz/product/MEMKHX3603970/Kingston-HyperX-Fury-16GB-RAM-2-x-8GB-DDR4-3200MHz
Yeah, that should work, can you find anything with lower latency? If you have the money then you should go for lower latency & faster speed
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783557
Yeah.  All B450 boards handle all the DDR4 3200MHz RAM you'll find.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783560
ok thanks, just one other thing would my current ram work its Ballistix Sport LT Gray 4GB DDR4-2400 UDIMM x2
It will work but fast RAM works much better with Ryzen CPUs, so if your budget allows it upgrade to faster RAM. If you can't afford to then it's still fine.
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783579
2 minutes ago, Baxman293 said:
shit, can i do that without getting an older chip?
Your motherboard could be already updated with the newest BIOS, but if you have a computer shop nearby they'll probably have older CPUs lying around and should be able to do a quick BIOS update for you.
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783626
Ok hopefully thats the case but if not i hope that the computer shops will be nice to me
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783632
I don't see why a computer shop would refuse something as simple as a BIOS upgrade. In fact I would be a bit surprised if they charge more then five dollars for it.
https://linustechtips.com/topic/1090939-i-need-help/#findComment-12783684
