Looking at benchmarks between the Ryzen 5 2600 & 3600: I would go w/the Ryzen 5 2600 + GTX 1660 TI.  What're the prices where you live and where do you live?  It's $150 for a Ryzen 5 2600X, currently, on Amazon
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
https://linustechtips.com/topic/1090795-build-help/#findComment-12782416
7 hours ago, Adsome2007 said:
A 2600 cost 130 dollars where i live but would it bottleneck the gtx 1660 ti
It would not bottleneck a 1660ti. The 2600 is rather powerfull, dont worry.
If you find any grammar or spelling errors please fill out entry permit A38, thanks.
Greetings from germany
Profilepicture by Chibiterasu-chan
https://linustechtips.com/topic/1090795-build-help/#findComment-12783533
If you quote people, then it'll give them a notification, so they'll come back to the post/thread and respond; don't forget, if you would like a reply  ?
Primary
E-HD:     12TB WD
https://linustechtips.com/topic/1090795-build-help/#findComment-12785399
