Difference between 270 and 270x
Go to solution Solved by D3MON,
you can find it anywhere, especiialy on this forum, they're the same, both 7870's, both come at pretty much the same clockspeed, both overclock pretty much the same, the "x" has an extra 6 pin to allow for more power BUT while a 270 tops out around 1100-1200 and 270x will top out 1150-1250, no its not really worth it.
that said if you have a choice between the same brand cards and the "x" is say $5 more then maybe you would get it for the e-peen..
Hi, I can't really find a straight simple answer. I was wondering what the difference between the r9 270 and r9 270x is in simple terms? I need to buy a graphics card for my dads build and don't know which I should go for.
Thanks
Mopman
|| Processor: AMD Ryzen 5 2600 || RAM: 32GB (4x8GB) Corsair DDR4 Vengance (3000) || Motherboard: ASUS Prime B450-Plus || Graphics Card: Gigabyte RTX2070 || Storage: 750GB SSD (2 Drives), 3TB HDD (2 Drives) || Case: NZXT H500 || Power Supply: be quiet! Pure Power 11 600W ||
https://linustechtips.com/topic/109050-difference-between-270-and-270x/
I think its simply a clock boost to my knowledge and apparently slightly higher pixel rate
http://gpuboss.com/gpus/Radeon-R9-270X-vs-Radeon-R9-270
So its not really worth the extra £20 for one? I assume the normal 270 is the re branded 7870? Which would be the same card as I have and that works fine.
Well my budget allows it so I am going to go for the XFX 270x.
Yes to my knowledge the R9 270 is a 7870 and the 270x is a 7870 GHz or just clocked at that
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
It's an exta £20 but the normal 270 won't be dispatched for 1 - 2 months whereas I can get the 270x Saturday.
oh you're in the uk, wait your sig says you have a 7870 already, you wanting to crossfire?
where you shopping to? ive been looking at the msi r9-270 gaming for £137 but might go r9-280x.
id suggest those 2 options overall, the difference between a 270x and 270 isnt worth thinking about let alone paying for.
edit: http://www.scan.co.uk/products/2gb-msi-radeon-r9-270-gaming-2g-28nm-5600mhz-gddr5-gpu-900mhz-boost-975mhz-1280-streams-dp-dvi-hdmi
edited
Its not going into my build and I wanted it from Amazon as I have Prime and want it tomorrow and ain't paying extra for shipping. I went for the 270x because it was in stock and I wasn't paying for it :P
