I know that on my Sapphire 7950 3L fans I can pop the fan of the motor and oil it, but does anybody know if it is possible on an asus 280x DCU2.
Thanks
Main rig: Coursair Air 540, Amd 8120(stock clock, had it up to 4.6), Gigabyte 990 fx ud3,  MSI DCU2 r9 280x, seasonic 1000w platinum, Samsung 830 64 GB ssd, Seagate 1tb, 4 GB (2x2) G.Skill,
Secondary: Define r4, Amd A10 5800k(4.6), 1x Sapphire 7950, MSI FM2-A85xa, 8 GB coursair vengeance ram, Seasonic 1250w Gold, 500GB 840 Evo, 223GB 2.5 Hdd, 80 Gb Seasonic, Samsung CD/dvd
https://linustechtips.com/topic/109005-oiling-gpu-fans/
Thanks
no because it shouldn't need it.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/109005-oiling-gpu-fans/#findComment-1456866
well one of the used ones I bought did need it, since after I oiled the shaft it stopped rattling and the fan returned to a normal rpm (it was visibly slower than the other fan on the same card)
https://linustechtips.com/topic/109005-oiling-gpu-fans/#findComment-1456951
