I swapped out my motherboard and CPU for an MSI MAG Z390 Tomahawk and a i7 9700k. Those are the only upgrades, but when I try to boot the PC it either goes to BSoD or freezes on prepairing automatic repair.
Iv'e read I should update the drivers, but I cannot access Windows.
All parts of the system are recognised correctly by the motherboard.
I tried making a bootable USB with Windows Media Creation Tool, but when I boot from it I get stuck on a frozen loading screen.
Let me know if you need more details.
https://linustechtips.com/topic/1089997-machine-check-exeption-after-upgrade/
Could be many things...
PSU not strong enough
faulty ram
faulty cpu
faulty mobo
faulty drive
overclocking issue
compatibility issues with the ram
Cabeling issue
faulty cables
just to name a few...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
What was your old motherboard and CPU? Driver conflicts are very common, it's often best to fresh install Windows.
Primary PC:
PSU tier list
How many watts do I need?
Asus prime b250m (maybe plus, cant check atm) and i5 7400 (again, not 100% sure, but something like that)
If it is driver errors, how would I fix that?
Fresh install or run in safe mode, but running in safe mode does t guarantee you can purge the old drivers
Primary PC:
PSU tier list
14 hours ago, lostboy said:
Never move a windows Install to a new motherboard setup.
I'd be looking into why your Windows freezes from the USB loader. Use a USB 2 port, USB mouse and keyboard.
Failing that, rebuild the USB stick with a new key.
Rebuilding the USB, is thar just formatting it again and re-running windows media tool?
Machine check exception is unstable hardware, not old windows installs.
MCE BSOD tends to only happen with a critical CPU failure on very light loads.  One way to trigger something like this on a working system is to try to boot at an absurd setting like 5 ghz @ 1.12v.  Usually you would expect clock watchdog timeout or whea uncorrectable, but you won't even get that far.
Freezing from a USB install is proof of that.
Is the PSU the problem then? I have'n ttied overclocking and all BIoS settings are on default. The power cord marked eith CPU says something with 12V. Could that be the problem? Dont think I have any other cords, do I just need a new PSU?
  • 4 months later...
Brand new MSI Z390 MB with i5 but same issue when trying to boot, BSOD results.  It doesn't matter if I use bootable USB with Windows Media Creation Tool or Flash drive,  I get stuck on a frozen loading screen.  I am ordering new RAM to see if that makes a difference (currently using 4 x 16 GB Corsair Vengance DDR4 2400).
