Its not worth it. Get SSD and R5 3600. Your current board should be able to handle it.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
2 minutes ago, sahadeo said:
i wanted to know if it is worth upgrade from a ryzen 5 1600 to a ryzen 5 2600 or should i get a new ssd and new mobo(b350m bazooka currently) to a x370 or x470?
I'd say neither.
Unless you need a new feature on the x470 your board will run a 3600 just fine.
