bios corrupted maybe, but I'm not sure how the board's own recovery works
Desktop benching:
https://linustechtips.com/topic/1087030-x370f-bios-problem/#findComment-12753971
17 minutes ago, Enzo1998 said:
Unfortunately I've not a second pc to download the bios, so I think I can only shut down and Try to reflash my current bios
so you can still get into the bios? Because this board itself cannot faslh its bios without a cpu, while a corrupted bios is unlikely to properly load up a CPU to do any BIOS flashing.
Desktop benching:
https://linustechtips.com/topic/1087030-x370f-bios-problem/#findComment-12754001
Ok I shut down the PC, and I could get into the BIOS and reflashad the BIOS, but now can't handle the previous OC settings and I'd to pass from 4.1 GHz at 1.337 LLC 4 to 4.1 GHz 1.35 LLC 4.
Now on the starting of Windows all cores stata at 4.1 GHz for 1 minutes.
Now i don't know of It Is an issue or not but i never recognised this boost at satring of Windows.
https://linustechtips.com/topic/1087030-x370f-bios-problem/#findComment-12754371
4 hours ago, Enzo1998 said:
Now i don't know of It Is an issue or not bit i never recognised this boost at satring of Windows.
That's normal. On Ryzen it has to stay completely idle for frequency to drop (and will go right back up even with only mouse movement) when you set your own multiplier.
Desktop benching:
https://linustechtips.com/topic/1087030-x370f-bios-problem/#findComment-12754972
