So my pc wont boot, the fans were spinning but have now stopped. The only light that appears is the one on the motherboard labeled SB_PWR. I am booting of an external hard drive. Here are specs and pictures
asus M5A97 Le R2.0
Amd fx 6300
corsair ddr3 ram
radeon hd 5700
lsu data 700w psu
also the fans were working and then stopped
https://linustechtips.com/topic/1087029-help/
3 minutes ago, jcooper2187 said:
Do you have another PSU you could test with?
Otherwise try taking everything out of the case and making sure it's all plugged firmly.
https://linustechtips.com/topic/1087029-help/#findComment-12753936
Ok cheers, could it be because i used these for standoffs because my case didn’t come with any?
https://linustechtips.com/topic/1087029-help/#findComment-12753948
Just now, jcooper2187 said:
more than likely not or else you would have always had issues, it could also just need to be dusted out well
https://linustechtips.com/topic/1087029-help/#findComment-12753950
10 minutes ago, jcooper2187 said:
Ok , anything else i could try?
Not really, kind of need spare hardware to test stuff like this, Is it your only PC? I assume you have no budget for a replacement if it is the only one.
https://linustechtips.com/topic/1087029-help/#findComment-12753981
Yeah but my other pc pc is msi b350 pc mate with a ryzen 5 1400 and a gtx 1050 ti so the chipset is different for the cpu right?
ya but probably just try the other power supply or something first.
https://linustechtips.com/topic/1087029-help/#findComment-12753985
Ok is that all i can do?
If it doesn't power on with a new power supply then it's probably just the motherboard that died
https://linustechtips.com/topic/1087029-help/#findComment-12753991
