Greetings all ?
I have an HPTC based on a thin ITX motherboard and both the SATA ports have drives on them.  I have an external enclosure for a slim disc drive that I have been plugging into USB ports, but when I was replacing one of the drives, I noted that I easily have room to mount it inside the case; are there any mSata to internal USB cables before I hack two cable together?
Thank you!
https://linustechtips.com/topic/1086090-help-with-finding-a-custom-cable/
@Arisaka
What do you mean by "slim disc drive"? Like an external DVD reader read over USB?
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
A slim disc drive, like the one in laptops.  I have an external case that lets it plug into USB.
I was able to find mSata to type A USB plug, but I am curious to know if there is a mSata to an internal USB header; crappy photoshop for effect.
Just get an internal port and extend the mSata to USB A, then USB A to internal header
https://www.officedepot.com/a/products/726581/Tripp-Lite-USB-20-Hi-Speed/?cm_mmc=PLA-_-Google-Mobile-_-Networking_Cables-_-726581&gclsrc=aw.ds&&gclid=CjwKCAjwg-DpBRBbEiwAEV1_-FHjDG8ndM6rwyuqFRFklOfM8WGSv3ZVs3X_o0UIsiP0Vm2DlsgpOxoCRFUQAvD_BwE
(Also I could have sworn mSATA was a different connector, and that's Slimline SATA?)
Primary PC:
PSU tier list
How many watts do I need?
you're right, that is a slimline Sata; forgot that... thanks for catching :)
And I saw I could use that sort of A to Header cable, but that is alot of bulk and length I don't need, which is why id just hack them into tone cable.  I am hoping there is just one cable that can do it, mostly because my soldering skill aren't good :)
Just now, SuperCloneRanger said:
thank mate.. this is helpful :)
