Does underclocking GPU help CPU bottleneck
Solved by Levent,
5 minutes ago, Bogdan7659 said:I was talking about RAM speed, its clock. For example, if I have a 1600 MHz RAM, will upgrading to a 2133 MHz one help?
Again, as I stated before you wont be gaining anything noticeable maybe %3-4 (if you go with highest memory that your board can support). IIRC FX series cpus are also quite picky when it comes to high speed memory.
I will state once again, you have to upgrade your cpu or overclock it, those are your only options to have a significant improvement (meaning noticeable).
