7 minutes ago, Sadman Tahsin said:
Wired pc
Well, there are many things that can effect your speeds:
  • Quality of connection i.e. poor WiFi signal / ethernet cable (they have different speeds, quality may differ, could be damaged?)
  • It's very likely you are on a shared connection instead of a dedicated line so other people living nearby can have an impact on your speeds
  • Distance to the server you are connecting to
  • The quality of the server's connection will also have an impact
  • If the connection to your ISP is wireless i.e. mobile internet, then signal strength will affect speeds
There are many more possible reasons.
Also consider that your ISP is likely advertising peak speeds.
It's been suspected that ISPs give unrealistically high priority to speedtest.net (https://news.ycombinator.com/item?id=14019723)
Not that it matters anyway. Internet speed is highly dependent on the factors that @SenioRR mentioned.
