Hyper 212 Evo backplate issue
Go to solution Solved by Bonsai99,
Yeah here it is.
Yeah I wouldn't put the backplate over that it might break it with all of the pressure.
Hello. I've got a problem with my motherboard and the Hyper 212 Evo back plate. The board is a Biostar TH55B. There is a small component on the board in the way of the backplate that prevents it from sitting flush.
post-35361-0-34024400-1391025068_thumb.j
Since the backplate has pads on it that appear to act as insulators, would it be ok to just place the back plate over the component? Alternatively, could I just use some plastic washers to widen the gap slightly?
Thanks.
https://linustechtips.com/topic/108583-hyper-212-evo-backplate-issue/
Thanks.
Can you highlight which component is in the way?
you can just use washers i used mine like that for 3-4 months before realizing there was a backplate
I kinda thought so. Would a plastic washer over each hole to make the backplate clear the component be okay?
Maybe, but if you bottom out the screws on the heatsink it may put too much pressure on the CPU die because of how the back plate is further back.
I would sell it and get another cooler. Something like the H55 i have, which comes with a plastic backplate.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
May you give us a side shot of the backplate?
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
