Sorry for long winded post but here goes.
I started with an msi b150m mortar and a 6700k(stock) with 32gb of vengeance lpx 3000mhz RAM, Samsung 860 Evo 500gb ssd, windows 10, and an evga xc ultra 2080ti. I swapped to an msi b450 tomahawk and a ryzen 5 3600(no x). Everything else is the same. I updated the bios to the new version which I believe was successful because I was able to boot and see in the bios that it had the updated version. However, from the git go I had issues with posting on a restart, or basically any time I had to shut it down which quickly devolved into just not posting at all. When I say not posting I mean that the fans would ramp up immediately, then it would hang, or they would ramp up and then come back down but I would get no output to my monitor from either the gpu or the motherboard. Everything else seemed to be working fine, just no video. The few times I was able to get into windows it ran perfectly with the exception of fans running like crazy due to them being on a non pwm splitter which I shut down the computer and removed to plug them directly into the motherboard. Since then I have not been able to post. I am exchanging the motherboard right now and will try again with the new motherboard but I am just curious if I am missing something. I tried getting it to post with nothing connected except the 8 pin eps, the 24 pin power, the case power switch and 1 stick of RAM (which was swapped several times for diagnostic purposes) while connected to the motherboard dvi and still got nothing. Many thanks to any help!
https://linustechtips.com/topic/1085501-intermittent-no-post/
Im in a good mood so I will read your entire post.  Alto its TLTR.
From what your talking about its a motherboard issue you have.  Do you see any red lights on it when you try to post.  You can try a different video card or better yet move your card to another PCIe slot and let us know.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1085501-intermittent-no-post/#findComment-12742863
OK so I exchanged the board, performed the update several times over now (on the phone with msi currently), I have the red post leds, they are coming on and performing the way they are supposed to according to the guy I'm talking to at msi. I still have no output though and the other pci slot is only 8x and isn't recommended for gpu but I'll try it.
https://linustechtips.com/topic/1085501-intermittent-no-post/#findComment-12743310
So new driver doesn't help, and while the model number on the sticker on the back of the monitor says it is a XL2430-B the gpu sees it as a XL2430T? I don't know what that is about however I still cannot display to the benq. I cant even click on it in the Nvidia settings. Very strange.
https://linustechtips.com/topic/1085501-intermittent-no-post/#findComment-12743391
