3 minutes ago, Mrfuzzy said:
i have an asus h81 775 motherboard an a nvidia qadro 600 graphics card, my card is responnding to power to not displaying what could be the issue
try with the cord to your mobo(if you have igpu), try gpu in another pc,try another pcie slot, try another gpu, check bios that the card is detected.
Technology is NEVER easy :(
https://linustechtips.com/topic/1084336-help/#findComment-12734457
