Can someone explain what "Smart Volume" is ?
Solved by T0MMEN,
UPDATE:
Turns out it is as you guys (and I thought firstly)
Extreme compresses the audio (although it didnt seem that way in games)
Soft does not compress as much.
I recorded a song (with the diffrent sound settings) took the audio and pasted it in Adobe premiere so i could look at the audio files.
1st track is no audio effect.
2nd track is soft
3rd is extreme
Featured Topics
Hellowpplz ·
Posted in Laptops and Pre-Built Systems0 -
1
2
E404Not_Found ·
Posted in New Builds and Planning5 -
Gavo ·
Posted in Troubleshooting4 -
3
4
2
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
