Upgrade advice
Go to solution Solved by Epimetheus,
1 minute ago, Reddox said:
Hi,
Around here, the 1060, the 1660, the 570 ans the 580 will be around 250 to 300$. They are all good options, the fight is more about 1660 or 580 condidering their better performance.
Should I trade the 10% increase in raw performance for 2g VRAM ?
no, if they're the same price get the 1660 unless you plan to use freesync
Hi,
I've recently been looking into an upgrade for my pretty light pc. Rn, here's what I'm rocking with :
-i3 8100
-GT 1030 2G GDDR5
-8G DDDR4
-450W PSU
So, my biggest upgrade is probably gonna be my graphics card (even though I'm probably gonna grab another 8g stick of ram on the way), and I was thinking of something like a 1060 6g.
This build is meant to be used in games like GTA (Five M), R6 siege, Civs and light content creation.
I was thinking that getting an upgrade on my CPU was also a good idea, but I have no clue of what to go for :/
My budget is around 400-500$
Any ideas ? ^^
https://linustechtips.com/topic/1083336-upgrade-advice/
How much does the 1060 6gb cost where you are? Usually the rx 580 8gb goes for less and offers slightly more performance with more vram.
For the CPU the only Intel CPU i'd suggest right now is the i5 9400F, it's pretty much the best in terms of price/performance if you can find it for around 150 dollars/euros
https://linustechtips.com/topic/1083336-upgrade-advice/#findComment-12726721
Hi,
https://linustechtips.com/topic/1083336-upgrade-advice/#findComment-12726742
Hi,
https://linustechtips.com/topic/1083336-upgrade-advice/#findComment-12726746
And the  i5 9400F is 160 bucks, so it's complety within range, I'll look into a few benchmarks and consider it as option 1 :)
https://linustechtips.com/topic/1083336-upgrade-advice/#findComment-12726748
A friend of mine had the i3 8100 paired with an RX 560 4GB Radeon card. he had some minor bottlenecks in Battlefield V multiplayer.
He upgraded his CPU to an i5 9400f and his GPU with an RX 570 8GB. That was a couple of weeks back.
Based on that, I can tell you upgrading the GPU would allow you some more performance (in Nvidia terms GTX 1050Ti level), but for a true boost, you'd need to upgrade the CPU too. An i5 6-core minimally. 8 cores would do even better.
In the RX 570 - GTX 1060 3GB - GTX 1060 6GB - RX 580 - RX 590 range the RX 570 offers the most performance for the lowest money (great fps per dollar ratio).
But, if you can, I'd recommend the RTX 1660.
Don't forget to flash the BIOS to the newest version before switching i3 8100 to some i 9000 series.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1083336-upgrade-advice/#findComment-12726760
