Hello all, im going to build a new rig soon, and was going to get a 650d, then I though about getting two r9 290's and though I might be a bit limited on airflow, but in the end im leaning towards to 780's acx. Intially I thought of using the 650d case, smaller, looks better (in my opinion), not a water cooler but the option is still there, a bigger mid tower, lots of space, and putting a dvd drive in i wont ruin the look of the sace, while the 750d does have more airflow. Going for a sniper 5, h100i cooler, and two 780 acx, would the 650d have enough airflow?
Mouse: Razer Death Adder 2013 Keybaord: Razer Black Widow Ultimate 2013
https://linustechtips.com/topic/108299-help-with-a-case-please/
It has a lot of airflow as well as rad space.
As mentioned not a water cooler, im gonna stick to air for gpus, and a closed loop for the cpu, too much hassle, too much money for water cooling. But how is the 650d airflow?
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447814
It will be all good but I would still lean towards the 750D because it will have better airflow than the 650D.
Quote me to get a reply!
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447819
Fair enough, this might be a stupid thing to ask, but do you think the case would look baren, with out water cooling, using the sniper 5, and 2 780s?
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447859
The cooler maybe, if you have the money I'd say go for the H320.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447865
Im not over clocking, just yet, and wouldnt the h320 be massive over kill for just a 4770k. I dont want to cool the gpus, this will be my first from scratch build, and i wanna keep it semi simple.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447887
If you want to keep it simple get a air cooler.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447893
Im open to suggestion on a good silent air cooler, that is not ugly like the noctua ones, and will keep witth he green/black/silver scheme im going for. I dont mind complications, just not a custom loop style one, a bit to much for me.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447900
I'd say for the Be Quite Dark Rock Pro 2/3.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447903
I really like that cooler, but what US stores seel them, amazon doesnt, except for people who go through amazon and want 200 usd fo rit, and new egg, and tiger direct dont. Do you know any? I wouldnt mind that cooler at all.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447917
NCIX has but I'd say wait a while and then buy it. http://us.ncix.com/products/?sku=93616&vpn=BK019&manufacture=be%20quiet!
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1447930
I can't really I'd just wait till it's released.
Cool well it says 5-10 days, so assume it will be availble soon thanks for the tip, this will be better the the h100i for me.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1448002
If you remove the drive bays, or at least remove the upper one and move the lower one to the inner position, the 650D should have sufficient air flow.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1448011
Ahh, so many sides to this story. In the end 650d looks better to me, and will fit better in my room. Will do the drive trick thanks, if i go with 650d which i most likely will.
https://linustechtips.com/topic/108299-help-with-a-case-please/#findComment-1448032
