Hello everyone,
I have $2500 US to rebuild my PC. I already have an Corsair CX850M PSU, Dual 250G SSD and 1TB HHD. Im planning to have an X570MB and Ryzen 9 3900. I would also prefer to use the M.2 and run it with 32G ram. any help would be great. The rig will be used for game play and game dev.
https://linustechtips.com/topic/1082045-2500us-build-help/
at this kind of budget you should just wait for the 16 core in September
Desktop benching:
https://linustechtips.com/topic/1082045-2500us-build-help/#findComment-12717479
23 minutes ago, Leegality said:
Hello everyone,
To be honest, I think in price to performance, you'd be better off getting a 3700X and a ROG STRIX cooler on the 2080Ti. The gaming difference is negligible between the two chips for a pretty good savings, and even for serious workload computing, the 3700X is incredibly solid.
https://linustechtips.com/topic/1082045-2500us-build-help/#findComment-12717484
PCPartPicker Part List
CPU: AMD - Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.00 @ B&H)
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($130.00 @ Amazon)
Memory: G.Skill - Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 Memory  ($139.99 @ Newegg)
Video Card: MSI - GeForce RTX 2080 Ti 11 GB SEA HAWK X Video Card  ($1089.99 @ Newegg)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($89.99 @ Newegg Business)
Power Supply: BitFenix - Whisper M 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.98 @ SuperBiiz)
Custom: Asus X570 TUF Wifi ($200.00)
Total: $2248.95
Generated by PCPartPicker 2019-07-13 21:59 EDT-0400
https://linustechtips.com/topic/1082045-2500us-build-help/#findComment-12717510
1 hour ago, trevb0t said:
1 hour ago, Herman Mcpootis said:
I'm unsure why the Ripjaws listing didn't appear when I was putting that suggestion together, but I fully agree with @Herman Mcpootis RAM choice over the one in my build :P MUCH better option.
https://linustechtips.com/topic/1082045-2500us-build-help/#findComment-12717630
6 minutes ago, trevb0t said:
I'd avoid TUF series boards, just based on the last few generations.
buildzoid quite liked the X570 TUF, claiming it cannibalizes their more expensive $200-300 motherboards.
https://linustechtips.com/topic/1082045-2500us-build-help/#findComment-12717922
