So I've built the PC, everything is hooked up.. but I can't install Windows. I use the USB and I make it to the first initial screen where I need to click next and it freezes. I have the msi meg ace mb and the code is usually stuck on 68-70 which are initializations. I can't power off the PC with the button, I have to turn off the PSU. What do I do????
https://linustechtips.com/topic/1081541-urgent-please-help/
What version of windows?
Where did you create the boot media from?
Have you tried to recreate the media using the Windows Boot Creation tool?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1081541-urgent-please-help/#findComment-12713806
maybe reseat everything? just to be sure first that you aren't having any potential poor connections between components
Daily Driver: Redmi Book Pro 14 - Core Ultra 7 155H | 32GB/1TB
Primary Desktop: NCase M1 - Ryzen 7 7800X3D/RX 6950XT | 32GB/2TB
Travel PC: Fractal Terra - Ryzen 7 5800X/RTX 3060 Ti | 16GB/1TB
I have too many computers. List here.
https://linustechtips.com/topic/1081541-urgent-please-help/#findComment-12714083
