so i finally got my 4k monitor back(i had to RMA it)
and i decided to play some games because why not
so i fire up gta 5 and im greeted by this: 1189mhz while at 100% gpu load
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1081076-gpu-iddling-speed/
You say 1189Mhz at 100% load. But in the picture it is 1189 at 0-1% load. Which one are you asking about?
If your problem is 1189 at 0% load then I think the problem could be that, on Nvidia Control Panel you have GPU power set to "High Performance". High Performance power mode is known to make GPU's run at higher than normal clock speeds at idle. Change it to Optimal and your GPU should go back to how it is "normally".
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
https://linustechtips.com/topic/1081076-gpu-iddling-speed/#findComment-12710512
What settings are you using? Because the perfCap reason implies you weren't really loading it.
Note that GPU load is likely "the GPU had something to do" rather than "the GPU was working this hard"
The clock speed is flat throughout.
https://linustechtips.com/topic/1081076-gpu-iddling-speed/#findComment-12710562
i was running very high settings at 4k and i was getting about 25 fps
a bios reflash fixed it though
https://linustechtips.com/topic/1081076-gpu-iddling-speed/#findComment-12712811
