Hello, so I found this while snooping around in Disk Management, I somehow can't create a new Volume base on an unallocated space, whenever I try to create a new volume, it says "The size of this extent is less than the minimum" (I've put less than the maximum). I've even tried deleting a volume to combine with the 149.12Gb but it didn't work. Thank you in advance :)
Hi This is my pc 😄
~ PC ~
Motherboard : B550 GAMING X V2
CPU : AMD RYZEN 5 5600X
RAM : 2x8Gb G.SKILL Trident Z RGB 2133 MHZ
SSD : Crucial P2 1TB PCIe M.2 2280SS SSD
GPU : AMD Radeon™ RX 6700 XT
PSU : M.RED ATX 750W - 80+BRONZE
Cooling : Watercooling M.RED AIO 240mm RGB Rainbow + 4 Fans
https://linustechtips.com/topic/1080826-storage-problem/
