So I installed a new 3700x into my system which replaced my 1600 I had before. On startup tho my screens are all black saying no signal. My keyboard also doesn't  light up. I have the motherboard im running it on is a b350. Could that be the reason?
https://linustechtips.com/topic/1080751-no-signal/
what motherboard are you using and have you updated the BOS?
https://linustechtips.com/topic/1080751-no-signal/#findComment-12707427
your motherboard might not support the new chips natively.
have you tried a bios update?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1080751-no-signal/#findComment-12707440
24 minutes ago, Kulak said:
Was going to do that but monitors aren't getting a signal
u need a compatible chip to do the bios update for most motherboard
since u have your old cpu, insert it and do bios update with it
https://linustechtips.com/topic/1080751-no-signal/#findComment-12707531
54 minutes ago, MVPernula said:
Aight:
  • Remove 3700x
  • Put the 1600 back
  • Update bios
  • Test with the 3700x again.
Should do the trick.
If not you may have to get a new motherboard.
Im not able to find my bios update on the MSI site i see all else but no b350 Tomahawk Arctic
https://linustechtips.com/topic/1080751-no-signal/#findComment-12707635
