Hi,
Never built a computer before, I've been looking into it, and picked some parts. The build is:
+Budget
+Should play games decently
+good storage
These are the parts:
https://uk.pcpartpicker.com/user/BobThePCBuilder25/saved/#view=BTCZf7
Could someone please check they are all compatible, my main concern is that they won't all fit in the case/work together etc etc. Also please let me know if I'm missing anything :)
*(Haven't included a GPU, the CPU has integrated graphics, I'm fine with that.)
https://linustechtips.com/topic/1080225-first-ever-pc-build-please-help/
1 minute ago, starcoaster said:
i suggest you replace the PSU with a CX450m, or perhaps a tx550m if you can spare the money. that power supply is "meh" at best.
also, if you have the budget, try and push the memory speeds up. 3000 or 3200 will be great.
otherwise, all the parts will fit and the build should boot up just fine
