Ryzen Master says my RAM is running at 1600MHz whereas both windows task manager and my mobo's bios say 3200.  Does anyone know why this might be?
Screenshots:
Edited by FezBoy
Screenshots
Resident Mozilla Shill.   Typed on my Ortholinear JJ40 custom keyboard
               __     I am the ASCIIDino.
              / _)
     _.----._/ /      If you can see me you
    /         /       must put me in your
 __/ (  | (  |        signature for 24 hours.
/__.-'|_|--|_|
https://linustechtips.com/topic/1079777-ryzen-master-incorrect-ram-speed/
DDR is double data rate. 3200 / 2 = 1600
You can run CMD to double check. Type "wmic memorychip get speed" and hit Enter. If its 3200 your RAM is running fine.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
So the actual clock speed is 1600MHz, it's just sending 2 bits per clock tick?  (I don't know if "tick" is the right word, but you hopefully know what I mean)
              / _)
/__.-'|_|--|_|
Yeah its sending 2 signals every clock cycle.
Also Ryzen Master is known for some inaccuracies such as their temperature readings and earlier versions didn't even show RAM speed properly, I personally wouldn't use it for overclocking tbh
