Programming course (Help plz)
Solved by Flojer0,
Given only a handful of years nearly any tools you learn today will be useless. So I would worry more about getting good at adapting to new tools than I would worry about the relevance of what I'm using. In fact, not to speak directly on the tools mentioned since I know little of them specifically, but I would consider it a benefit to cut teeth on worthless tools so that you are forced to adapt before beginning anything more than tutorial level work.
