Hi,
i was checking my cpu temps and saw my cpu was hitting 100c as soon as i ran almost any game.
First off, everything is stock, i didnt overclock and i dont intend to.
In bios i saw that cpu vcore showed 1.39v and after some digging i updated the bios. Now vcore in bios says 1.192v and system keeps crashing after 1 minute in windows. Please help me.
Motherboard is Gigabyte z97x gaming 3 and bios is updated to F7
https://linustechtips.com/topic/1079262-i7-4790k-problems/
Heat could be due to poor airflow or improper thermal paste application or cooler installation. It could also be too high voltages or misreported temps software wise. As with the crashes after the BIOS update it might be due to the fact that it's at a much lower voltage at auto to be stable at all with the clocks it's at.
CPU: AMD Ryzen 7 2700X; GPU: MSI RTX 2060 Gaming Z; MoBo: MSI B450 Gaming Plus ATX; RAM: TForce Delta TUF RGB 3200MHz (2x8) 16GB;
Case: CoolerMaster MB511 RGB TG; PSU: Seasonic Prime FX Gold 750W Fully Modular; CPU Cooling: Cooler Master MA620P; Storage: WD Blue 250GB SATA SSD & Seagate Barracuda 2TB 7200RPM; Monitor: MSI MAG241C 144Hz Curved Gaming Panel; Keyboard: Corsair K95 RGB Platinum (MX Brown); Mouse: Fantech X11 Daredevil
https://linustechtips.com/topic/1079262-i7-4790k-problems/#findComment-12700150
