GPU heatsinks leave much lacking.  If you get a PCIe extension, and don't care about having a compact rig, you can give them breathing room sufficient to mount a superior CPU heatsink on them.  Emphasis here on "mount".  GPU and CPU mounts differ sufficiently that this isn't simple.  I don't have a 3-d printer or access to machining equipment to make my own.  Does anyone know of adapters that could mount a CPU heatsink on a GPU?
(and, yes, I've looked at GPU heatsinks.  and, I don't want to hook up an AIO to watercool the GPU.)
https://linustechtips.com/topic/1078424-cpu-to-gpu-mount-adapter/
I would say no
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
2 minutes ago, goto10 said:
zipties, zipties everywhere
direct methods to mount i only have seen a mount module for a waterblock, i think is evga, otherwise is all diy, there is a youtuber called diyperks that has done it, his channel has some videos about the theme
That guy had a 3-d printer.
They literally make kits to mount CPU AIO coolers to GPUs. I believe NZXT and a few others make them.
Otherwise if the dies didn't line up neither would the through-holes and you won't be able to mount it flush with anything "secure" like screws. Then the zip-tie apocalypse would take over.
Thrashcore band name:
Zip-tie Apocalypse
But it wasn't necessary for attaching the heatsink. In his videos, you can see that a metal sheet or cnc'ed wood works with some standoffs.
https://youtu.be/Iegpwo9SqSg
https://youtu.be/h6hvsqUEtZ4?t=212
I didn't pay close enough attention.  Thanks for pointing that out.
