Hello, i am considering upgrading my current GPU which is a GTX 970 . Should i go with either the vega 56 £235 or gtx 1070 £334 or maybe something else even?
Secondly, would one of these cards bottleneck with my current system? :
i5 4670k @4.3ghz
16gb ram 2400mhz
MSI GAMING 5 mobo
seasonic 650w psu
Any help is much appreciated
https://linustechtips.com/topic/1078064-gpu-upgrade-help/
2 minutes ago, harryp2404 said:
I would go with the Vega 56 just because of the price to performance, the 1070 probably has better performance but is more expensive.
the CPU should be fine aswell :)
The Vega 56 should trade blows with the 1070. In some games 1070 will be superior(sometimes not by small margins), and sometimes Vega 56 can start performing similar to a 1070Ti/1080. Since it's so much cheaper I'd get the vega.
Also, a 4670k is more than enough for a vega in most scenarios, especially overclocked.
i5 4670k @4.3ghz
16gb ram 2400mhz
MSI GAMING 5 mobo
seasonic 650w psu
What model is your PSU?
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687735
yeah the price is really good, and looking at benchmarks its outperforming the 1070 frequently if not on parr
the problem is the heat, i imagine. and im so used to nvidia with the drivers, control panel and such
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687737
Power draw and heat will be issues, make sure the card you're getting has a decent cooler, and i'd probably suggest adding your own thermal paste in. highly recommend thermal grizzly kryonaut for that
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687740
Also, a 4670k is more than enough for a vega, especially overclocked.
thanks bro, my psu is seasonic m12 620w evo i think , had it for years
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687742
According to the PSU tier list, it's a tier C PSU. Should serve you decently for a few more years. Your system should pull like 550W at max(like, GPU 100%, CPU 100% kinda thing, which is rare).
2 minutes ago, seperate28 said:
also, i want to play skyrim with enb at decent performance
Vega 56 and 4670k should give you decent performance, this video shows someone using a 1070 and a 7600k getting minimum like 50-60FPS. The Vega 56 should be similar to the 1070 and the overclocked 4670k should perform similarly to a 7600k
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687753
thanks for your help
 i built the system in 2015, do you think the power supply will last long enough and not destroy components?
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12687757
If I were you I’d upgrade to something like a Corsair RM750x, 4 years seems like a decent period to upgrade a low-ish quality PSU
https://linustechtips.com/topic/1078064-gpu-upgrade-help/#findComment-12688603
