I am experiencing a problem in dying light where i can only hear the character's voice and thats it! i cant hear gunshots i cant hear zombies i cant hear any effect. i tried reinstalling nvidia driver cuz it has audio driver i tried another headphones i disabled surround sound from logitech software i changed sound quality from windows and still didnt work and i also plugged my headphones in the pc directly instead of connecting them to the sound card then to my keyboard (my keyboard has usb slot) and still no fix. none of my friends have this problem. i also checked the audio settings in game and they are fine.
https://linustechtips.com/topic/1077382-dying-light-sound-problem/
1 minute ago, InfernalClaw said:
i already said i did if you read what i said well @will4623
couldn't tell you only said you did in windows
Edited by will4623
I said linux instead of windows
I live in misery USA. my timezone is central daylight time which is either UTC -5 or -4 because the government hates everyone.
2 hours ago, InfernalClaw said:
the sound quality you know how many bit and how many hz i tried many options and they still dont work
What are you currently on in these settings? And have you tried switching them?
I noticed you said you disabled surround sound but not sure if you tried these Windows settings instead of your Logitech software.
  • 4 months later...
On 7/3/2019 at 1:13 AM, InfernalClaw said:
i fixed the problem i had to adjust something in my headphone settings in logitech @Dr. Historic Low
Hi, i'm also using a logitech headphones...and having the same problem... what did u do to the settings in logitech?
  • 2 years later...
hello bro, i too am facing the same problem. can you pls help me and tell me what settings did you change or anything that might solve this problem
i think if i remember correctly i didnt find a fix for it. sorry
