I have the asrock x58 extreme 3 mobo and thermaltake versa n25 case. everything was working fine until yesterday when i found out that my steelseries 7h headphones aren't working. I tried them on a different device and yes they are working and I tried different headphones on the computer and they are still not working. seems to be a jack issue but how come it happened overnight. also i have the case's audio connectors properly connected to the mobo but the front jacks aren't working either for some reason(though i don't know if they ever did before, never tried)
https://linustechtips.com/topic/1076849-headphone-jack-not-working/
Run DDU "Display Driver Uninstaller" in safe mode and choose drop down box to RealTek.  Do a clean and restart, then your back into normal mode;  Now install the latest Realtek HD AUDIO drivers and let us know what happens.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
didn't work. evthn is same as before
Ok thanks for trying at least.  There is another solution.  Run System Restore and go back to a date where the jack worked.
i dont maintain system restore points. and besides i popped the same boot ssd into a different computer and it's working fine. rules out software problems seems likes the jack's messed up but the question is how
Have you tried all holes ?  The RealTek software changes inputs to whatever you want.  Try a different input, You should have 6 inputs,, 1 mic and 1 line in.  Then front and rear and center / sub.  As said before with RealTek onboard it doesn't matter where you connect the jack because the software will recognize and you can choose its use as front speaker or stereo speaker input.  Let us know when you tried all inputs except for mic and line in.  Try the Rear speaker output.  You can use any input for front speakers and headphones, try both rear and front while the realtek control panel is running.
