https://www.amazon.ca/DEEPCOOL-FH-10-Integrated-Occupying-Motherboard/dp/B077YHLDSP/ref=sr_1_3?keywords=fan+hub&qid=1561659836&s=gateway&sr=8-3
Never used this one but it has good reviews, its cheaper, and its powered via sata rather than molex. I use the silverstone one but that one was 40 CAD (Dont know what that is in freedom dollars but oh well).
Gaming Rig:
CPU: Ryzen 7 3700x  Cooler: Wraith Prism    RAM: 32gb G.Skill Tridentz RGB 3200mhz     Mobo: Asrock X570 Taichi
Graphics Card: Powercolor Red Devil RX 5700 XT     Case: Fractal Design Meshify C Dark TG     PSU: Corsair RM850x
Storage: 250gb Samsung 960 EVO, 2TB Seagate Barracuda
HTPC/VR Rig:
CPU: Ryzen 5 1600     Cooler: Noctua NH-L9a     RAM: 16gb Crucial Ballistix Sport 3200mhz     Mobo: Gigabyte B450 Aorus Pro Wifi ITX
Graphics Card: Powercolor Red Devil RX 580 8gb     Case: Fractal Design Node 202     PSU: Corsair SF600
Storage: 120gb Kingston A400, 500gb Samsung 860 EVO
Streaming Rig:
CPU: Ryzen 5 1600 @ 4ghz OC     Cooler: Cooler Master Hyper 212 Black Edition    RAM: 8gb Corsair Vengence LPX 2400mhz     Mobo: ASRock B450 Pro4 MATX
Graphics Card: Powercolor Red Dragon RX 570 4gb     Case: Inwin 301 White/Blue     PSU: Evga 450BR
Storage: 240gb Crucial BX500, 1TB Seagate Barracuda
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12676767
What motherboard and fans are you using?
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12677327
6 hours ago, Brandon Preshyon said:
What fans?
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12679368
7 hours ago, WoodenMarker said:
What fans?
i have alot of fans most of them are 4 pin connectors snice i do like to control the speeds with my bay drive controller. as for brand noctuals and corsairs are pretty much what i mostly like not big on RGB fans
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12680128
What drive bay controller?
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12680977
its a very old one can't remember the name of it theres no brand names on it. Its just a device that goes into the one of the dvd drive slots that has fan controls on it an it reads the speeds of them aswell
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12682441
Can you post some photos of it?
If you like the controls on it, you can probably just use splitters off of it since it should have plenty of power being plugged into the psu.
Alternatively, you can split from the motherboard fan headers if you like the onboard motherboard fan controls as long as you don't exceed 1A per header.
https://linustechtips.com/topic/1076538-fan-hub-controller/#findComment-12683265
