I need help my pc went black while playing arma and now i tried restarting it but all it does is go into automatic repair i cant do a reinstall because it says , "additional free space is needed on the drive where windows is installed. Free up some space and try again." But i cant because my pc wont boot up at all and i dont know how to delete files from here or anywhere else please help , i havent been able to find anything else like this on the internet,  thank you
https://linustechtips.com/topic/1076423-need-help/
just continue to Windows after the atuo repair shows up?
Desktop benching:
https://linustechtips.com/topic/1076423-need-help/#findComment-12675133
I do but then it infinitely loads and then it restarts and infinitely loads again
https://linustechtips.com/topic/1076423-need-help/#findComment-12675142
then you have to use a Windows 10 install USB drive to either repair your current install or just nuke the old one and start fresh
Desktop benching:
https://linustechtips.com/topic/1076423-need-help/#findComment-12675150
Sounds like you have a dead drive. What drives do you currently have in the system? Do you have another drive that you could test with?
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
https://linustechtips.com/topic/1076423-need-help/#findComment-12675151
27 minutes ago, dgsddfgdfhgs said:
how about sd card in your phone?
anyway you DO NEED A WORKING system to download windows to usb
So my pc booted but im trying to scan my pc with avast and it just gets to like 26 percent and then finishes should i just reinstall windowa any ways or what ?
https://linustechtips.com/topic/1076423-need-help/#findComment-12675222
