Any clue on how to crop a selected region of an image and paste it onto another image? For ex: cropping a character and pasting it onto another image
  • CPU
    AMD Ryzen 5 1600
  • Motherboard
    MSI B350 PC Mate
  • RAM
    Team T-Force Vulcan 16GB (2x8)
  • GPU
    ASUS Geforce GTX 1060 6GB
  • Case
    Phanteks Eclipse P400
  • Storage
    WD 1TB 7200RPM, WD Blue 500GB SSD
  • PSU
    CORSAIR CX Series CX650 650W
  • Display(s)
    Dell SE2717HR 27" 75HZ
  • Cooling
    AMD Wrath Spire
  • Keyboard
    Rosewill Neon k85
  • Mouse
    Rosewill Neon m59
  • Operating System
    Windows 10 64-bit Pro
https://linustechtips.com/topic/1076338-gimp-v2-help/
Selection tool. You can do rectangular, circular, free hand or scissors (about at the line). Use Ctrl and Shift to add or remove parts of selection. Then you copy selected (make sure you have correct layer selected) and paste either as floating (default) or by some other method.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1076338-gimp-v2-help/#findComment-12676004
I've got it. But I do not like where I need to manually and take my time to trace around what I need removed or copy. I also use microsoft 3D paint and it has the same function but it does it automatically.
  • CPU
    AMD Ryzen 5 1600
  • Motherboard
    MSI B350 PC Mate
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
    AMD Wrath Spire
  • Keyboard
    Rosewill Neon k85
  • Mouse
    Rosewill Neon m59
  • Operating System
https://linustechtips.com/topic/1076338-gimp-v2-help/#findComment-12677175
Well, scissors do kinda that. Or you can choose with magoc wand.
https://linustechtips.com/topic/1076338-gimp-v2-help/#findComment-12677729
