means you have a great, stable connection to whatever you're pinging?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1075818-same-ping/#findComment-12670154
it fell  fake to me too stable  i even got it to google  and google dns  like the  fake pin sever is right in this town and trace route never work
finally found a sit that is not the same this site
https://linustechtips.com/topic/1075818-same-ping/#findComment-12670159
no way to fake a ping test and response.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1075818-same-ping/#findComment-12670161
how come
Traceroute has started…
traceroute to google.com (172.217.10.78), 64 hops max, 72 byte packets
 1  iqrouter.menu (192.168.7.1)  1.477 ms  1.822 ms  1.178 ms
 2  lga34s14-in-f14.1e100.net (172.217.10.78)  12.860 ms  4.340 ms  6.510 ms
i got this from my pc and my router give me
traceroute to google.com (172.217.10.78), 30 hops max, 38 byte packets
 1  *
 2  100.41.9.244  5.103 ms
 3  *
 4  *
 5  140.222.225.219  7.719 ms
 6  72.14.218.232  6.735 ms
 7  *
 8  209.85.251.82  7.630 ms
 9  108.170.246.2  6.511 ms
10  108.170.235.157  9.972 ms
11  216.239.57.248  10.778 ms
12  108.170.227.149  9.642 ms
13  108.170.248.33  11.179 ms
14  216.239.42.165  8.791 ms
15  172.217.10.78  8.530 ms
https://linustechtips.com/topic/1075818-same-ping/#findComment-12670179
Tracerts take longer because it has to report back what path it took to get their. While a ping does not care about the in-between. 8ms is really good and there is no way or reason you should think it is fake or false. There is no way to fake a ping response time at all. I personally get 6ms to 8.8.8.8
https://linustechtips.com/topic/1075818-same-ping/#findComment-12670312
i was most ask now why the trace router from pc show the top one and from the router show   the full route
https://linustechtips.com/topic/1075818-same-ping/#findComment-12671933
