Hi all.
im new here, and i need Tip on my New Loop..
i have now a tank inside. and a Show tank in front ( just For Cool )
and i like to make a Tube or sort outside my case,
Big and Long  like (1M or 40 inch) like a long glass tube
with tubes outside my case,
im runing amd - 4.10 ghz @ 23 degrees with 6 Fans 2 in - 4 out..  so i dont think its to Hot.. :P
is it a great idea to build a big tank to cool it more. or only stress on the pump ?
* and is there more Cooling in that what you put in a car ? that cooling liquid ? can you cool a PC with it ?
Love the LTT shows..
* sorry for my english im from the netherlands.
gtzz :P
https://linustechtips.com/topic/1075720-custom-water-loop/
Not completely sure on your questions.
But the tanks / reservoirs don't help anything with cooling. It's literally only to make sure your pump doesnt run dry.
Coolant ment for a car wont do anything good for your PC either. It's ment to make sure the cooling system in a car don't corrode or freeze. It doesn't cool any better.. Probably the opposite. It's just the same as liquid made for use in PC's includes additives to prevent corrosion amoung other things.
If you want to cool it better, then you need more / bigger radiators. :)
https://linustechtips.com/topic/1075720-custom-water-loop/#findComment-12669482
