Just now, Dujith said:
I dont think its used. Cheaper to have 1 model with all preparations for RGB then 2 separate models.
So while the connector is there i doubt there is any RGB on the cooler itself.
well the cooler got a "hard swap" feature, were u can change the normal fans to RGB fans. Tho those fans use the power they get dirrectly from the fan power.
https://linustechtips.com/topic/1075469-gpu-led-pins/#findComment-12667153
