Hi.
I have 16gb of DDR4 3200Ghz and for some reason when I put an xmp profile it makes my CPU go above its turbo boost speed.
It may be harmful for the cpu and I was wondering if anyone knew a way which would prevent this (ASUS Bios)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/
@Derrk What is the normal voltage for i7-8700 none k
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665477
@Derrk How do I see the voltage? Is it inside the Bios?
If it is high do I immediately change back to default?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665497
If you've turned on an XMP profile and left everything else go, you have nothing to worry about. Nothing will be damaged, even in the long term. People daily drive these CPU's (the K version that is) at and above 5Ghz which requires well more voltage than you're seeing currently, or will ever see for that matter.
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665499
@TempestCatto So I just enable XMP profile #1 (I didnt create that btw its just there)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665507
@TempestCatto Its sits around 1.3 on the motherboard and 1.5 on the ram is this ok as well as 4.20 to 4.60 cpu speed I manged to turn up to 3000ghz
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665540
If you didn't set anything manually, and simply just enabled XMP, everything will still be AUTO. So you'll be fine.
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665547
It said do I want to change intel settings on cpu or something like that I said no and it just went XMP profile 1
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665549
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665550
@TempestCatto How would I know if there is a problem?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665553
You would know if there's a problem if you have stability issues. Like I said, if the only thing you touched is XMP you have nothing to worry about. If you're still that worried, you could also reset the CMOS and just not touch anything in the BIOS.
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665556
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665558
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665561
@TempestCatto Yo, from what I see it doesn't go past 1.35 voltage on the cpu
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665583
@TempestCatto Yo, its going to around 1.38 now is still ok? My temp increase a bit though ( sits around 45c when gaming now its 55-60c)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665621
It will go up and down with usage unless you force it to something in the BIOS. Everything is still fine.
https://linustechtips.com/topic/1075271-ram-help/#findComment-12665690
