I saw some good 1080,1080 ti used on random stores as not sure are they worth it and safe to buy will i get a warranty if something does not work?
I saw some have the water cooling all in one aio but do they last longer as the fan version of it and do i need to worry miners and people who overclock them for long time.
https://linustechtips.com/topic/1075143-used-card-advice/
They'll usually tell you if you get a warranty or not. I'd say it's anything between no warranty and under 2 years but I'm not sure.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/1075143-used-card-advice/#findComment-12664536
If you worry so much then it may not be worth it because your mind will fixate on negatives all the time. Buying used means you need some faith.
https://linustechtips.com/topic/1075143-used-card-advice/#findComment-12664549
If it’s from a company that has a transferable warranty and the orginal owner registered it and is selling it to you, then sure. No other reason should make you believe there’s any kind of warranty.
Dont see what miners or overclocking has to do with any of it.
Sample size is is too small to suggest if an aio version would last longer than fans. User error plays a larger factor there as well.
Blower fan would outlast any third part fan setup.
Either way you can get many years out of a card without issue. Buy new or deal with the used gamble that everyone does everyday.
https://linustechtips.com/topic/1075143-used-card-advice/#findComment-12664791
